Startup and running config
Feb 27th, 2008
How would you see if there is a difference in the startup and running config of an IOS switch?
lamav Wed, 02/27/2008 - 11:51
Execute a "sh start" and then a "sh run" and view the configurations side-by-side and line-by-line to see the differences.
skhirbash Wed, 02/27/2008 - 11:56
If you have saved any modification to the running-config file, then there will be no difference and therefore you won't be able to compare. Otherwise, what I would do is the following:
- sho running-config till the last line.
- copy the contents and paste to a text editor.
- reload the device
- sho startup-config
- compare each line in the startup-config file against the contents you have pasted in the text editor(which should be the running-config file).
Hope this helps.
lamav Wed, 02/27/2008 - 12:06
Why does he have to reload the device just to get the output of a 'sh run" and a "sh start"?
skhirbash Wed, 02/27/2008 - 13:56
That step is not really necessary; however, I assumed that there could be a possibility of a corrupt startup-config file and reloading the device can verify it.
lamav Wed, 02/27/2008 - 13:59
OK. I hope he reads your explanation before he submits a change control just to check the start up config. :-)
There's a suite of commands just for this:
That link is for router IOS but the commands are preset on recent switch software revs. They're "unsupported" so they don't show up in the switch documentation and therefore I can't tell you what minimum rev you need to be running. I also believe you need to be on a switch family >=3550.
Edit: I just checked my Cat6.5k (SUP2/MSFC2) and the command is not present. My Cat4.5k does have it. Bottom line is YMMV. :-)
Edit2: You also need to specify the file system where the files are that you want to diff. In your case, system:running-config and nvram:startup-config
