paolo bevilacqua Wed, 02/27/2008 - 11:49
  • Hall of Fame,
    Founding Member
Yes, under bvi interface, try configuring traffic shaping with the value you want.
If that doesn't work because it is a virtual interface, you will need to apply input shaping to the fa0/0 instead, but you will need to do that for the subnet used by BVI1, using an ACL.
