which interface are gig on the 5510
Feb 27th, 2008
I have 2 asa 5510 that I upgraded to security plus license. Im suppose to have 3 10/100 and 2 10/100/1000 interfaces. which one are the gig interfaces. not of the ethernet or management can be set faster then 100Mbps
martinwonglc Wed, 04/09/2008 - 07:29
Please find the reference below:
"ASA 5510 Security Plus License Allows Gigabit Ethernet for Port 0 and 1
The ASA 5510 adaptive security appliance now has the security plus license to enable GE (Gigabit Ethernet) for port 0 and 1. If you upgrade the license from base to security plus, the capacity of the external port Ethernet0/0 and Ethernet0/1 increases from the original FE (Fast Ethernet) (100 Mbps) to GE (1000 Mbps). The interface names will remain Ethernet 0/0 and Ethernet 0/1. Use the speed command to change the speed on the interface and use the show interface command to see what speed is currently configured for each interface"
MrJake Wed, 04/09/2008 - 09:23
The problem was i was using 8.0(2) and the speed command was not letting me go higher then 100. I was told to upgrade to 8.0(3) and now it works.
Thanks for the reply though
