ASA5550
Feb 27th, 2008
We want to purchase ASA5550, this FW come with 8 Gig interface + 1 FE + 4 gig SFP. My questions are:
1) Can we use all these interface "or if we use the copper the fiber are disabled"?
2)We want to use: One copper interface "As an Outside Interface"
, Three copper interfaces "An an Inside Interface" and One fiber interface for failover. Can we do that?
tmesbah Wed, 02/27/2008 - 14:22
I can do it in my first or second question ?
Or in both ?
abinjola Wed, 02/27/2008 - 14:26
  • Cisco Employee,
you can use in both option 1 and 2
andrew.burns Wed, 03/05/2008 - 09:11
  • Gold, 750 points or more
1) You can't use all the interfaces at the same time. Basically the 5550 has two buses, corresponding to Slot0 and Slot1. The 4 copper ports in Slot0 can always be used. However, you can only use a total of 4 ports from Slot1, which can 4 fibre, 4 copper, or any combination.
2) Not sure exactly what you mean by 3 copper interfaces "as inside", do you mean 3 separate DMZ's?
Andrew.
