WAAS VLAN - not all traffic is being forwarded to WAE
Feb 27th, 2008
Hi, I've configured a WAAS topology based on this Cisco document
(http://www.cisco.com/application/pdf/en/us/guest/netsol/ns377/c649/ccmigration_09186a008081c7da.pdf)
where the WAE's are in their own VLAN and there is a trunk between the 2 edge routers and 2 6509 switches (the WAE's connect to this switch). Both the "data" vlan and the WAAS vlan is participating in EIGRP which means that traffic is being routed over both sub-interfaces. The problems is that one of the sub-interfaces has the "ip wccp redirect exclude in" command configured so only half the traffic will be passed to the WAE's. Has anyone come across this before? Should I be removing the WAAS vlan from EIGRP and using the second interface on the WAE for management in a seperate subnet?
interface GigabitEthernet0/0
description Trunk link to 6500
no ip address
interface GigabitEthernet0/0.901
description WAN Edge VLAN
encapsulation dot1Q 901 native
ip address 10.7.7.2 255.255.255.224
ip wccp 61 redirect in
ip wccp 62 redirect out
interface GigabitEthernet0/0.902
description WAAS VLAN
encapsulation dot1Q 902
ip address 10.7.9.1 255.255.255.240
standby 1 ip 10.7.9.3
standby 1 timers 1 3
standby 1 priority 110
standby 1 preempt delay minimum 1
standby 2 ip 10.7.9.4
standby 2 timers 1 3
standby 2 priority 120
standby 2 preempt delay minimum 1
Edge_Router#sh ip ro 10.6.1.181
Routing entry for 10.6.1.0/21
Known via "eigrp 1", distance 90, metric 28928, type internal
Redistributing via eigrp 9
Last update from 10.7.7.1 on GigabitEthernet0/0.901, 08:18:01 ago
Routing Descriptor Blocks:
10.7.7.1, from 10.7.7.1, 08:18:01 ago, via GigabitEthernet0/0.902
Route metric is 28928, traffic share count is 1
Total delay is 130 microseconds, minimum bandwidth is 100000 Kbit
Reliability 245/255, minimum MTU 1500 bytes
Loading 12/255, Hops 3
* 10.7.9.1.2, from 10.7.9.1.2, 08:18:01 ago, via GigabitEthernet0/0.901
Zach Seils Fri, 02/29/2008 - 08:33
  • Cisco Employee,
BRADLEY,
In this case you should make the data VLAN passive (from an EIGRP perspective) and use the WAE VLAN as a transit between the two routers. You don't want traffic coming in from the WAE VLAN to get re-intercepted.
Zach
