Migration off of Vlan 1
Feb 27th, 2008
CDP, VTP and numerous other services ride on Vlan 1 by default. If I create a new "management" vlan and put an IP address on that vlan, how do those previously mentioned services communicate with each other?
Is there a "default vlan #" command that will force all that "management" traffic onto a vlan other than vlan 1?
I guess my question is, can I migrate those management processes off of vlan 1 and leave user traffic on vlan 1?
Jon Marshall Wed, 02/27/2008 - 23:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Jason
Vlan 1 will always be used for CDP/VTP/PagP packets even if you change the management vlan to something else. Management in this context means a vlan used to remotely access and administer the switch not management in terms of CDP/VTP/PagP.
So no you cannot move this type of traffic off vlan 1. And you shouldn't really use vlan for user traffic or unused ports either. In fact if you can try not to use vlan 1 for anything that is under your control.
Jon
