Error Firmware is not running
Feb 27th, 2008
I am having an error on cisco 2800 with VWIC-2MFT-E1 card, below is the error.
%CONTROLLER-2-FIRMWARE: Controller E1 0/3/1, firmware is not running
can any one please guide how to resolve the issue.
graemeporter Thu, 02/28/2008 - 01:14
Hi Ahmed,
You should try upgrading to the latest version of the IOS on that router, if you haven't already done so. This error is suggestive of a conflict between IOS and the firmware on the card.
Also, ensure you're using the right IOS image for your particular model of 2800-series.
Have you used this card successfully on that router previously? If not, has it worked with any other router, even a different model of router?
Kind regards,
Graeme
