ospf area issue
Feb 28th, 2008
Hi all
In ospf process,they require inject a default route to area 4, should i configurate the area 4 is a stub or totally stub area?
one more a question:
if i wanna an area in ospf process can only receive the inter-area route and must not receive the External route, what should i do
thanks advance
Overall Rating: 2.5 (2 ratings)
Jon Marshall Thu, 02/28/2008 - 00:43
1) Configure as a totally stub area and only a default route will be injected into the area ie. no external or inter-area routes will be advertised into area 4
2) Configure as a stub area which will allow inter-area routes but not external routes.
shivlu jain Thu, 02/28/2008 - 22:15
If you have any connectivity behind the area 4 means rip or eigrp then you can make the area 4 as NSSA,. Else you can make the area 4 as total stub area. After doing this you will be reciving a one default O*E2 route.
