"Show isdn active" : No output
Feb 28th, 2008
I am not able to view the history as well as the active calls if i use "show isdn active" command on the router 3845.
Need help.
mat.walker Wed, 03/05/2008 - 17:15
Are you using MGCP on your gateway and perhaps ISDN L2/L3 backhauling?
I noticed also there was no "show isdn active call" etc etc type output when using isdn backhaul under MGCP.
mat.walker Thu, 03/06/2008 - 15:50
Yeah, as I thought.
It seems that you do not get any "show isdn xx" output when your backhualing ISDN L2/L3 to CCM via MGCP.
Certain "show isdn active/history" commands state: "%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply"
I'm guessing most likely because the CCM is controlling the D channel on the ISDN the gateway doesn't get to see much of it from a ISDN L3 perspective, probably because the CCM has its CDR's with which to track calls.
hemant.wavhal Fri, 03/07/2008 - 05:30
Yeah...this could be the reason that sh isdn active/history does not show any output...
Thanks a lot for help...
