1841 Router -QSIG
Feb 28th, 2008
Does anyone know if the 1841 supports the VWIC-1MFT-E1 module for basic QSIG functionality because the 1841 product documentation indicates data only.
VWIC-1MFT-E1
1-port RJ-48 multiflex trunk-E1
v (data only)
I am not sure what (data only) means ?
Appreciate your help,
Paul
Paolo Bevilacqua Thu, 02/28/2008 - 03:46
Data only means that the router does not support terminating voice channels, hence it cannot be used with any PBX, QSIG or not.
The smaller router model that supports QSIG and more is called 1861. You also need a PVDM2-xx where xx is the number of voice channel you intend to handle (8, 16, 32, 48 or 64).
