CiscoWorks Assistant: does not support the installed Common Services Vers.
Answered Question
Feb 28th, 2008
I seem to have a problem that occurred already with CW Assistant 1.0. I have read CSCsk19350 but in my understanding this should be fixed in CW Assistant 1.0.1.
My setup:
SunOS nms-cw2k 5.9 Generic_122300-13
CW Assistant 1.0.1
CW CommonServices 3.1.1
CW LMS 3.0.1
If I do a comparison with http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_assistant/1.0.1/user/guide/cwa_tbs.html
I seem to have a supported installation. I tried to search bugtool for CWA but I am too stupid to use this tool to do a forward search (I was not even able to find CSCsk19350 without knowing the exact ID). I guess that there might be other problems with CWA. Does somebody have any experience with this error?
Thanks for any hint.
Mat
Correct Answer by Joe Clarke about 9 years 2 months ago
This problem is almost always due to a bad System Identity User configuration. Try resetting your System Identity User and password under Common Services > Server > Security > System Identity Setup and Common Services > Server > Security > Peer Server Account Setup. The username and password need to match in both places.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 02/28/2008 - 08:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Are you getting an error about the installed Common Services version not being supported? A screenshot of what you're seeing would be helpful.
Correct Answer
Joe Clarke Fri, 02/29/2008 - 00:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
MATTHIAS SCHAERER Fri, 02/29/2008 - 06:35
Hi Joe,
once again your support is awesome. Thanks a lot, you made my weekend!
Mat
alacie-77 Fri, 06/19/2009 - 09:03
Ciao
I got the same problem and tried to reset the two passwords but the problem is still there.
I'v been working on this error for 3 days nad I did get any findings......can you help me please
Thans
Joe Clarke Fri, 06/19/2009 - 09:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please start a new thread for your problem.
