VLAN Routing
Feb 28th, 2008
I have 5 Vlans in my L3 Switch i want to all 4 vlans traffic to route via my ISA Proxy sever (Proxy Server Connected to 1st ISP) and . I want to route the 5th vlan traffic via my ASA firewall (ASA is connected to 2nd ISP )
rickyjohnt Fri, 02/29/2008 - 21:42
This is the sample configuration for PBR
access-list 1 permit ip 1.1.1.1
access-list 2 permit ip 2.2.2.2
interface fastethernet 1
ip policy route-map equal-access
route-map equal-access permit 10
match ip address 1
set ip default next-hop 6.6.6.6
route-map equal-access permit 20
match ip address 2
set ip default next-hop 7.7.7.7
route-map equal-access permit 30
set default interface null0
From this above sample configuration can you please explain the below mentioned two lines two lines
Please refer my N/W Diagram attached with this mail
rickyjohnt Fri, 02/29/2008 - 21:44
match ip address 1
match ip address 2
royalblues Sat, 03/01/2008 - 00:17
  • Green, 3000 points or more
Ricky,
The configuration tells the router to do PBR i.e to look at the route-map equal-access before making the forwarding decision.
BTW, as per your earlier post you wanted one of the vlans to be sent to the ASA and hence the above command should actually be configured under the VLAN SVI
Narayan
rickyjohnt Sat, 03/01/2008 - 00:36
Can you tell under which VLAN i have to configure that
Please refer the Network diagram and tell
me
royalblues Sat, 03/01/2008 - 00:54
As per the network diagram, both the ISA and ASA are having the same ip address 10.0.17.1
Also i am not sure which vlans traffic needs to go the ASA from the network diagram
for eg... if you require vlan 5 traffic to go to ASA, then configure it under vlan 5 interface
int vlan 5
ip policy route-map
You also need to make sure that the access-lists are defined properly which are eferenced under the route map
Narayan
rickyjohnt Sun, 04/13/2008 - 23:15
access-list 105 permit ip x.x.x.x x.x.x.x any
interface vlan 4
ip policy route-map test
route-map test permit 1
match ip address 105
set ip default next-hop x.x.x.x (ASA Gateway)
I tried this but it is not working
