Delay in switchover of sup720
Feb 28th, 2008
When we do forced switchover from one supervisory card to another, the delay in switchover is approx. 10 sec which seems to be on the higher side.
We are having 7613 router and running SSO.
mode sso
auto-sync running-config
Previously it was working fine. Recently the delay is showing.
Thanks in adv.
owillins Wed, 03/05/2008 - 06:47
The initial reload after the configuration of the High Availability (HA) is longer and the reload after is normal because initially, both Supervisors need to synchronize in order for HA to work properly
