Can I insert some digits into dialed number(CCM4.2)
Feb 28th, 2008
  • Bronze, 100 points or more
I have the following numbering plan 6XXXX2XXX . Digit "6" is obligatory.Then XX - is number of region, and next XX number of station. All internal numbers are in 4-digit format and start with 2. Now the question)) :
Can i somehow insert this "2" into dialed number?(the user will dial 6-11-22-001 - and get transformed number 6-11-22-2001) Probably transorm 6XXXX like a prefix into 6XXXX2? Any ideas are welcomed.
smahbub Wed, 03/05/2008 - 08:24
  • Silver, 250 points or more
Yes you can try with Digit manuplation under Dial pattern also try with translation pattern
