DMA Error: 4.2.3 to 6.0
Stefano Amici
Hi all,
i'm trying to migrate a 4.2.3 four servers cluster to 6.0 release by DMA tool. The export process and validation ended successfully with warnings while the installation process terminated with an error.
The error logged was:
Error executing "insert into processconfig (fkprocessnode,paramname,paramvalue,tkservice,primarydata,tkparam) values('00000000-1111-0000-0000-000000000000','MaxServers','30',11,'f',2)": [Informix][Informix ODBC Driver][Informix]Cannot insert a null into column (processconfig.pkid)
Stefano
Jaime Valencia
seems you're hitting this bug:
CSCsl26081
Upgrade from CUCM 4.2(3)SR3 to CUCM 6.0(1) fails
java
if this helps, please rate
Jaime Valencia
CSCsl26081
java
It works.
Thanks a lot
