NAT in Router 850
Feb 28th, 2008
Hello
I have a Router Cisco 850, with C850 Software (C850-ADVSECURITYK9-M), Version 12.4(4)T7.
I need to do NAT between an IP 19x.xxx.xxx.13 to three IPs: 192.168.210.248, 192.168.210.249 and 192.168.210.250.
I do this configuration:
interface FastEthernet4
ip address 19x.xxx.xxx.13 255.255.255.240
ip nat outside
interface Vlan1
ip address 192.168.210.200 255.255.255.0
ip nat inside
ip default-gateway 1xx.xxx.xxx.14
ip classless
ip route 0.0.0.0 0.0.0.0 1xx.xxx.xxx.14
ip nat pool pool1 1xx.xxx.xxx.13 1xx.xxx.xxx.13 netmask 255.255.255.240
ip nat inside source list 10 pool pool1 overload
access-list 10 permit 192.168.210.250
access-list 10 permit 192.168.210.248
access-list 10 permit 192.168.210.249
When I do:
#sh ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
FastEthernet4
Inside interfaces:
Vlan1
Hits: 106096 Misses: 6056
CEF Translated packets: 111874, CEF Punted packets: 458
Expired translations: 6187
Dynamic mappings:
-- Inside Source
[Id: 4] access-list 10 pool pool1 refcount 0
pool pool1: netmask 255.255.255.240
start 1xx.xxx.xxx.13 end 1xx.xxx.xxx.13
type generic, total addresses 1, allocated 0 (0%), misses 0
Queued Packets: 0
#sh ip nat translations
(Nothing appear)
If I do a telnet from a remote computer to 1xx.xxx.xxx.13, open the login from this router, and not what I want, an address from list 10.
What I need to do?
Thanks in advanced.
José Goncalves
reglendxhango Thu, 02/28/2008 - 05:45
First OF all delete the default gateway
no ip default-gateway 1xx.xxx.xxx.14
no access-list 10
access-list 100 permit ip host 192.168.210.248 any
access-list 100 permit ip host 192.168.210.249 any
access-list 100 permit ip host 192.168.210.250 any
access-list 100 deny ip any any
interface vlan1
access-list 100 in
Hope this helps
jose.m.goncalves Thu, 02/28/2008 - 06:31
Thanks for the answer.
But this doesn't resolve the problem.
I want to use the IP 1xx.xxx.xxx.13 as the external IP to access to the internal (3) hosts.
And the same way, the internal hosts use this IP 1xx.xxx.xxx.13 to communicate to the external computers.
Best regards
Jose Goncalves
reglendxhango Thu, 02/28/2008 - 07:24
With This Configuration you can use The Public IP 1xx.xxx.xxx.13 to communicate to Internet.
If you want to Access your private Addresses from a Public IP you have to make NAT-MAP based on service for example:
ip nat inside source static tcp 192.168.210.248 80 1xx.xxx.xxx.13 80 extendable
This Maps the tcp 80 (or Http) to the 192.168.210.248.
There is no other way you can comunicate from Public to Private Network.
Brgds
jose.m.goncalves Thu, 02/28/2008 - 07:50
Thanks. Now I understand better the problem.
I can use 1xx.xxx.xxx.13 to communicate to 192.168.210.250.
But if want that the three internal IPs use the same IP 1xx.xxx.xxx.13 to communicate to the Internet, how can configure the router?
This is my problem.
Thanks for your patience.
José Gonçalves
