L2TP over IPSec - XP Client - Cisco 3000 VPN Concentrator
Feb 28th, 2008
I'm using the following reference.
Configuring L2TP over IPSec from a Windows 2000 or XP Client to a Cisco VPN 3000 Series Concentrator Using Pre-Shared Keys
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a0080094aca.shtml
I've got the connection working fine my question is security related. If I understand this correctly there is no encryption used with this config. When looking on the concentrator the session shows as having no encryption. I want to use this for our remote users but I need it to be secure (encrypted). Is there any way to use the native XP VPN client with the Cisco 3000 and using something like 3DES?
Jason Weir
GARYLANOIE Thu, 02/28/2008 - 12:46
Wow, I am having the same exact problem. After following the instructions to the letter, the user is connected but without any encryption. Let me know if anything comes of this.
Gary Lanoie
