netManager UC and IP Phone
Feb 28th, 2008
Hi all,
We are installing netManager - Unified Communications but the software does not discover the IP Phone registered with the ccm cluster.
We do see the ccm cluster and its status, but we don't see the registered ip phone.
Any idea ?
Many thanks,
Laurent.
yigitzorlu Thu, 04/10/2008 - 02:58
Laurent,
I am having the same issue. I think if netmanager software is not in the same broadcast domain with the IP Phones it doesn't autodiscover the phones. Did you manage to make it work?
Yigit
noushad.cisco Wed, 02/04/2009 - 01:54
Configure the CCM cluster perfectly in netmanager by enabling snmp services (depends of os of ccm it vary). Then we can see all ip phones inside the ccm itself.
anil.k.oruganti Wed, 02/04/2009 - 12:09
Hi ,
I have CUCM installed on MCS 7825 hardware. I dont see any object identifier for this type ( 7825/cucm) in devices list supported by net manager. Does my SNMP work if configured on CUCM with Net Manager.
