Unable to sync configuration from Active
Feb 28th, 2008
Dear All,
My secondary PIX started to reboot automatically and it is giving below messages.
My pix is 515E with 8.0 OS
Can some body tell what can be the problem
========================= NOTICE =========================
This platform is licensed to run in
failover secondary mode only
Detected an Active mate
amritpatek Fri, 03/07/2008 - 07:25
  • Silver, 250 points or more
Check if the failover cable is connected properly and not damaged. If this does not helps configure failover on some other interface of the device.
