Error: GetNewFileName-fopen in wb mode failed to update existing file
bbeck
The entire message I am getting in my application event logs is "Error:GetNewFileName-fopen in wb mode failed to update existing file. szFileNumberName=E:Traces\DBL\DBL_CTFTP~num.bin." It seems to a permissions issue not allowing access to write to trace files. Has anyone seen this and knows how to fix the permissions?
bwilmoth
Level 5
Level 5
You may be hitting with this bug:CSCed38443
