show ip traffic output
Answered Question
Feb 28th, 2008
Hi, I am troubleshooting my slow internet link. I know that the line is congested but I also suspect that there is some delay issues? How can I find out if I have unacceptable delays on the line to the internet. I also ran show ip traffic if anyone can see anything that stands out out of the ordinary. I am concerned about the "362598 bad hop count" and "39 not a gateway" Thanks for all of your help!!
IP statistics:
Rcvd: 599649297 total, 38630812 local destination
0 format errors, 0 checksum errors, 362598 bad hop count
20987819 unknown protocol, 39 not a gateway
0 security failures, 0 bad options, 2 with options
Opts: 2 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump
0 other
Frags: 17 reassembled, 0 timeouts, 0 couldn't reassemble
0 fragmented, 0 fragments, 0 couldn't fragment
Bcast: 24145480 received, 0 sent
Mcast: 4724488 received, 7187721 sent
Sent: 32104091 generated, 320548701 forwarded
Drop: 1567345 encapsulation failed, 0 unresolved, 0 no adjacency
5800 no route, 0 unicast RPF, 0 forced drop
0 options denied
Drop: 0 packets with source IP address zero
Drop: 585 packets with internal loop back IP address
ICMP statistics:
Rcvd: 68 format errors, 3260 checksum errors, 8 redirects, 601340 unreachable
4362319 echo, 1800 echo reply, 5 mask requests, 0 mask replies, 9 quench
0 parameter, 5 timestamp, 4 info request, 2 other
0 irdp solicitations, 0 irdp advertisements
Sent: 8252276 redirects, 3738364 unreachable, 2270 echo, 4362283 echo reply
0 mask requests, 0 mask replies, 0 quench, 5 timestamp
0 info reply, 362028 time exceeded, 0 parameter problem
TCP statistics:
Rcvd: 1250813 total, 916 checksum errors, 143085 no port
Sent: 4865688 total
BGP statistics:
Rcvd: 0 total, 0 opens, 0 notifications, 0 updates
0 keepalives, 0 route-refresh, 0 unrecognized
Sent: 0 total, 0 opens, 0 notifications, 0 updates
IP-EIGRP statistics:
Rcvd: 4724851 total
Sent: 7188145 total
PIMv2 statistics: Sent/Received
Total: 0/0, 0 checksum errors, 0 format errors
Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0
Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
Queue drops: 0
State-Refresh: 0/0
IGMP statistics: Sent/Received
Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
DVMRP: 0/0, PIM: 0/0
Queue drops: 0
UDP statistics:
Rcvd: 6697418 total, 31 checksum errors, 3334300 no port
Sent: 3334018 total, 0 forwarded broadcasts
OSPF statistics:
Rcvd: 0 total, 0 checksum errors
0 hello, 0 database desc, 0 link state req
0 link state updates, 0 link state acks
Sent: 0 total
ARP statistics:
Rcvd: 11816278 requests, 43625 replies, 0 reverse, 0 other
Sent: 1424235 requests, 876948 replies (0 proxy), 0 reverse
Correct Answer by paolo bevilacqua about 9 years 3 months ago
Hi, bad hop count is basically the number of times the router was being traversed by traceroute. Not a gateway is harder to define, but just consider that a malformed packet. I would be a bit wary of "unknown protocol".
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Thu, 02/28/2008 - 09:39
  • Hall of Fame,
    Founding Member
bsudol79p Thu, 02/28/2008 - 09:50
OO Ok, well we are a graphics company so we have a lot of MACs and they have whole bunch of stuff running over IP, so I am not surprised by that number of unknown protocols stat. Thanks for the help!!
