MGCP Dial-Peer Question
Feb 28th, 2008
I'm confuguring SRST for a customer who runs MGCP. I am going to create the needed dial-peers, COR etc.. for when router falls back to h323. My question is do I need to keep the below dial-peer in the configuration for MGCP and CCM to work properly when NOT IN SRST mode? Or is this dial-peer still needed? Am I correct that with CCM controled MGCP gateway no dial-peers are needed on the gateway (other than the pots dial-peers that are automatically configured (FXS/FXO dial-peers).
dial-peer voice 100 pots
preference 1
application mgcpapp
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 2/0/1:23
thank you
