NAT problem
Feb 28th, 2008
Hi All,
I have been stuck with NAT problem. It gives me a error my ASA. like this
No translation group found for icmp src fugen-dmz: dst outside: (type 8, code 0)
These hosts are coming from interface etherent0/3 (named as fg-idsys) on my ASA but here it says it comes from ethernet 0/2 (named as fugen-dmz).
when i see my security level the eth0/3 is high than the eth0/2. Probably i think it falls to low security level to reach outside.
The hosts connected to the eth0/2 are able to reach outside.
Attached my NAT configs
Let me know what is missing in NAT configurations
NAT show outputs
Mohamed Sobair Thu, 02/28/2008 - 10:33
why the NAT of (fg-idsys) shows:
nat (fg-idsys) 1
this means it doesnt match any thing,
Could you clarify your nat config,
caliber01 Thu, 02/28/2008 - 11:15
i have now changed that to
nat (fg-idsys) 1
Mohamed Sobair Thu, 02/28/2008 - 12:22
Hi Caliber,
Great to be of help.
The Normal Security level for the LAN is 100 and this shouldnt affect any Nat operation.
caliber01 Thu, 02/28/2008 - 12:38
I agree with it . security level doesn't affects NAT.
But wondering why my error message on ASA shows like
If you look at the error it shows src fugen-dmz but actually the hosts are connected to fg-idsys
four interface in ASA
eth0/0 - outside with public ip address level 0
eth0/1 - Internal security level 100 LAN
eth0/2 - DMZ (named as fuen-dmz) security level 50
eth0/3 - Named as fg-idsys security level 70
i want some of my hosts to reach outside interface through fg-idsys interface.
ican able to ping from host to fg-idsys interface (vice versa) but they were not able to go internet.
The hosts that were connected to fugen-dmz and internal where able to go outside and able to get internet.
Mohamed Sobair Thu, 02/28/2008 - 14:39
Hi caliber,
Have you configured access-list or associated the Interface subnet to the Nat pool.
could you double check,
caliber01 Thu, 02/28/2008 - 15:03
i haven't created any ACL 's for this.
I m sure something is missing in my NAT config. I couldn't able to find it.
i have configured PAT.
Mohamed Sobair Thu, 02/28/2008 - 16:22
Pls double check the ip address at interface (fg-idsys), i think it should be changed to be within 172.16.x.x subnet.
also add the following:
nat (fg-idsys) 1 access-list fg-idsys
you have already ACL permits the Pool to any destination but not associated with it
caliber01 Thu, 02/28/2008 - 16:58
i have changed my ip address of the fg-idsys to
and also given the suggested NAT config on ASA
like this
but still the error message is the same and they were not able to reach outside.
