LAN & ROUNTING ISSUES: SUP 720 and FWSM
Feb 28th, 2008
I Have a FWSM running in multiple context mode with two context configured, each context is using a differente SVI for communication between the MSFC and the FWSM. From the beginnign the solution has been workin fine and traffic between contexts and DMZ flows without problem, however when in type a "show interface" for the SVI's in the MSFC to see the traffic passing to each context, the counters of the SVI's don't register any traffic in the 5 minute input/output. Currently the switch is running in Hybrid mode (CatOS/IOS). Previously I have installed another FWSM's in a very similar scenario but using switches in NAtive mode and in the case the shi interface for the SVI's do detect the traffic passing to the context's, is it normal this behavior for the Hybrid switch ???
Thanks in advance.
mchin345 Wed, 03/05/2008 - 14:06
  • Silver, 250 points or more
Could you provide more info about your question ie show running , device series and feature?
