H245 Tunneling
Feb 28th, 2008
Is there a way to disable H245 tunneling on the dial-peer by dial-peer basis?
Instead of disabling the entire gateway by using voice service voip under H323 using H245 tunnel disable.
This is on a AS5400HPX gateway.
teodorgeorgiev Fri, 02/29/2008 - 00:34
  • Bronze, 100 points or more
Create a voice class with a particular number, configure there "h245 tunnel disable" (or you can switch to "call start slow") then apply
this voice-class number to the desired dial-peer
