Error when VPNing with IPAQ
Feb 28th, 2008
I am using Bluefire software on my Ipaq and am receiving the following error sometimes:
Feb 28 15:22:16 [IKEv1]: Group = basic, IP =, Removing peer from peer table failed, no match!
Feb 28 15:22:16 [IKEv1]: Group = basic, IP =, Error: Unable to remove PeerTblEntry
I say sometimes because it will connect and then the next time I try and connect I get this error on the PIX. When it fails to connect the bluefire software shows "Failed to negotiate phase 2 with the Tunnel gateway server.
My config should be fine as laptops have no issue when connecting with the Cisco VPN client using the same crypto map statements.
Can anyone shed some light on what that debug statement means?
It is frustrating because it will work and then 10 minutes later it doesn't.
