Credit card pos connection to VG224
sohaildxbfze
is it possible 2 connect credit card pos to vg224(with mgcp) to go thru one of the e1 channels????
6 Replies 6
sohaildxbfze
Hi, evrybudy!!!
I am still waiting for an ans,, any1 ready to help!!!!!!!!!!! much appreciated in this concern
Steellllllllll0
It will work fine although some machines speed settings will need to be tweaked a bit.
Regardless of speed settings,
when i connect any analog phone or fax maxhine on that vg port it works f9.but when i connect credit card pos it says "No Carrier" on pos screen.
chrispducky
Anyone have answer to this would appreciate if you can share the solution if any? We have similar problem. It worked intermittently which makes it really frustrating.
Our setup is
SIP GW-----CUBE---MGCP---CUCM-----SCCP----VG224----Credit Card POS
IOS version Version 15.1(3)T for the VG224
Fax/Phone calls etc works fine on the ports but somehow Credit Card POS is giving issue.
voice service voip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
voice-card 0
stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 2/0
fallback-dn 12345
no ccm-manager fax protocol cisco
sccp local BVI1
sccp ccm 10.1.1.1 identifier 5 version 7.0
sccp ccm 10.1.1.2 identifier 4 version 7.0
sccp ccm group 1
associate ccm 4 priority 1
associate ccm 5 priority 2
voice-port 2/0
timeouts ringing infinity
caller-id enable
dial-peer voice 1 pot
service stcapp
port 2/0
Is there any special settings that need to be done for Credit Card POS?
kind regards,
Patrick
Gordon Ross
Level 9
Level 9
Credit Card machines do work through ATAs and VG224s. The machines sometimes only run at a fixed modem speed and refuse to downspeed (I've only seen modems across VoIP go to about 28.8 Kb/s) So if they're hard-coded to run at, say, V90 or even V92, then you're stuffed. When they do downspeed, they're not always great at it. In my experience, embedded modems are generally rather poor quality. If you can force the speed (19.2Kb/s is usually a good speed) then that can help.
Putting fax & modems across SIP tunks over the Internet adds even more complexity to the mix.
Also, I've come across a lot of credit card companys who refuse to support machines running across VoIP phone systems. Either they claim they don't work or that they are less secure than traditional phone systems. In the extreme, they'll cut off service until you put the machine on a traditional PSTN analogue line.
GTG
Please rate all helpful posts.
Thanks for that response Gordon, might check on that. This is what I tried so far but not much joy.
1. Disable noise generation
2. Disable VAD
3. Set codet to G711 a-law (outside of US)
config t
voice-port 2/0
no vad
no comfort-noise
compand-type a-law
I got those settings suggestion from a basic deployment guide of credit card machine.
It did mention about reducing the speed as you mentioned, namely set the baud rate to 9.6Kbps and to disable ECM in the Terminal POS. Will try contact the bank support and see if they can help set that or send their technician to set it.
regards
Patrick
