User is not able to leave voice mail after no answer timeout and busy
Feb 28th, 2008
I have problem with Unity, when caller External User is not able to leave voice mail after no answer timeout and busy.
Call flow PTSN->h323 gateway ->ccm->Unity connection
I create a translation pattern on ccm for translate all incoming calls from PTSN to voicemail pilot number and when I call to this number from outside the office I hear on ring and after no answer timeout and busy User is not able to leave voice mail . In office voicemail working propertly.
What could be causing this anomality?
Can anyone to review this call flow?.
"2","2008/02/27","21:34:00","Appl","attemptforward"
"2","2008/02/27","21:34:00","Conv","State - d:\commserver\localize\scripts\attemptforward.cde!Dummy"
"2","2008/02/27","21:34:00","Conv","Event NULL"
"2","2008/02/27","21:34:00","Appl","phtransfer"
"2","2008/02/27","21:34:00","Conv","State - d:\commserver\localize\scripts\phtransfer.cde!LoadInfo"
"2","2008/02/27","21:34:00","Conv","Event is [TrueEvent]"
"2","2008/02/27","21:34:00","Appl","phgreeting"
"2","2008/02/27","21:34:00","Conv","State - d:\commserver\localize\scripts\phgreeting.cde!Root"
"2","2008/02/27","21:34:00","Conv","State - d:\commserver\localize\scripts\phgreeting.cde!PlayGreeting"
"2","2008/02/27","21:34:00","Conv","Call answered if needed"
"2","2008/02/27","21:34:00","Disp","Playing greeting for Call Handler: AA_Credinissan"
"2","2008/02/27","21:34:04","Conv","DTMF [5]"
"2","2008/02/27","21:34:07","Conv","DTMF added [499#]"
"2","2008/02/27","21:34:07","Conv","Event NULL"
"2","2008/02/27","21:34:07","Conv","State - d:\commserver\localize\scripts\phgreeting.cde!Play_BailAtGreeting"
"2","2008/02/27","21:34:07","Appl","phtransfer"
"2","2008/02/27","21:34:07","Conv","State - d:\commserver\localize\scripts\phtransfer.cde!LoadInfo"
"2","2008/02/27","21:34:07","Conv","Answer Phone if needed"
"2","2008/02/27","21:34:07","Conv","Event is [FalseEvent]"
"2","2008/02/27","21:34:07","Conv","State - d:\commserver\localize\scripts\phtransfer.cde!CheckPlayTransferIntro"
"2","2008/02/27","21:34:07","Conv","Event is [TrueEvent]"
"2","2008/02/27","21:34:07","Conv","State - d:\commserver\localize\scripts\phtransfer.cde!PlayTransferIntro"
"2","2008/02/27","21:34:09","Conv","Event NULL"
"2","2008/02/27","21:34:09","Conv","State - d:\commserver\localize\scripts\phtransfer.cde!XferCall"
"2","2008/02/27","21:34:10","Conv","Event is [HangupEvent]"
"2","2008/02/27","21:34:10","Conv","State - d:\commserver\localize\scripts\phtransfer.cde!DoHangUp"
"2","2008/02/27","21:34:10","Appl","Idle"
"2","2008/02/27","21:34:10","Conv","Idle"
"2","2008/02/27","21:34:10","Disp","Idle"
Jaime Valencia Mon, 03/03/2008 - 21:02
  • Cisco Employee,
  • Hall of Fame,
    2011
if you call the same translation pattern internally does it work?
you reach first this:
then you press 5
"DTMF [5]"
what do you have for the caller input for 5?
attempt transfer or send to greeting?
also to what are you routing when pressing 5?
a subscriber? a call handler?
in any case does the destination element is enabled to take the message?
is using the attempt transfer on caller input what do you have as the transfer options for the destination element?
send to greeting? ring subscriber? ring subscriber at this extension?
what should be the whole call flow on this?
santiago_figuer... Tue, 03/04/2008 - 10:54
Thank you for your quick response:
nothing, no option on caller input for 5
no one
subscriber now, but we tried with both of them.
yes
ring subscriber extension (we've tried with ring subscriber at this extension and ring subscribers extension)
Best Regards,
Claudio.
Tray Stoutmeyer Tue, 03/04/2008 - 21:05
  • Cisco Employee,
I see it says
Which is the "Wait While I transfer your call."
Then see a hangup.
It's hanging up somehow during transfer it seems. You would need to get some traces going to see why both on the Unity side and the callmanager side. If you don't know how to do this, I would recommend opening a TAC case.
