IOS related
Feb 28th, 2008
Hiii
I have a cisco 2960 switch.and i would not upload IOS for the cisco 2960 switch.When i am given IP in switch and local PC via conected for TFTP.
And When i m given these command it shuld give me error.
My cisco Switch IOS :-
Flash:C2960-Lanbase-MZ.122-35.SE5/C2960-Lanbase-MZ.122-35.SE5.bin
command:-
1-Copy flash TFTP
2-Source file :- for the switch
3:-IP address:-for PC
4:-Destination file:- for locate folder
5:-TFTP on
Error for that it should not connect
Please Help me immediate?:------
Pushpendra Kumar Tiwari
Network Engineer
guruprasadr Thu, 02/28/2008 - 23:18
  • Gold, 750 points or more
HI Pushpendra, [PLs rate if helps]
Can you please POST the Error you are getting during IOS Upgrade.
>> Ping from Switch to PC and viceversa = it should be OK and provide Ping Response only then you can do successful IOS Upgrade.
>> Make sure the TFTP is correctly mapped to the Folder where the correct IOS is stored.
>> Make sure your Windows XP / 2000 PC firewall is turned OFF.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
