File transfert problem with anyconnect
Feb 29th, 2008
We have a problem with the anyconnect client (version 2.1.0148). An user has installed this client on his computer (Windows Vista 64 bits).
He has no problem to make a connection to your ASA 5520 (version 8.0(3)).
He has also no problem to communication to internet or other server in our school. But when he want to download a file (26 MB) from his computer to a windows server of our school, the transfert fails. (see picture: error.png).
You can also look the picture "statistics.png", the anyconnect connection statistics.
Everyone has the same problem?
I have tried to download some files with the anyconnect client (but on Vista 32 bits) and there is no error. The transfert is ok.
It's a bug on anyconnect client for Vista 64 bits?
Thank you for your help.
Bests Regards!
Sam
sadbulali Thu, 03/06/2008 - 07:34
  • Bronze, 100 points or more
workaround, disable compression in the group-policy (svc compression none). Try BUG - CSCsg26365
s.fasel Tue, 03/11/2008 - 23:46
thank you for your solution, but it does not work.
