RTMT in a Citrix enviornment?
Feb 29th, 2008
Is RTMT (CUCM 5.1) supported in a Citrix Presentation server 4 environment. The install guide suggest not..
"You can install RTMT, which works for resolutions 800*600 and above, on a computer that is running Windows 98, Windows XP, Windows 2000, (Cisco Unity Connection 2.1 only) Windows Vista, or Linux with KDE and/or Gnome client...."
Has anyone tried this using Citrix? Are there any limitations?
Thanks Steve
Jaime Valencia Fri, 02/29/2008 - 17:50
  • Cisco Employee,
  • Hall of Fame,
    2011
As the documentation that you find explains, Citrix is not a supported platform for RTMT to be installed on.
not sure if someone has ever tried this, i just looked into this and found only another guy asking this but he got the info you already have
Officially Citrix is not a supported platform for RTMT.
ssparkes Wed, 03/05/2008 - 23:40
I guessed this would be the case. I think we will put it on and try it...If we run in to problems the thing can come off!
