IDS Event Viewer error
Feb 29th, 2008
when i am trying to add new device, am getting the bellow error....kindly provide me information
IOExpection when try tog get certificate; untrusted server cert chain Check if the sensor time and IEV host time are set correctly
Overall Rating: 3 (1 ratings)
mhellman Fri, 02/29/2008 - 06:04
  • Blue, 1500 points or more
You might try connecting the sensor via HTTPS with a browser and taking a look at the certificate. If your browser doesn't like it, it should tell you why.
sureshkum Mon, 03/03/2008 - 06:58
Thanks a lot..After once apply the Certifi again, got the connectivity..
