Spanning Tree Basics
Feb 29th, 2008
For a basic Spanning-Tree setup is this a good starter...
Designated root bridge commands;
spanning-tree mode pvst
spanning-tree vlan xx priority 4096
And all other (non-root) bridges commands;
I know other things like UDLD and BPDU Guard are useful, but for a basic mesh setup are the above commands enough to be going on with and avoid Loops?
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 02/29/2008 - 03:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Mike
I generally do the following.
1) Select 2 switches to be spanning tree root primary and spanning tree root secondary.
2) On primary root -
spanning-tree vlan xx priority 8192
3) On secondary root
spanning-tree vlan xx priority 16384 - where vlan xx is the same vlan number as in 2).
If all your switches support Rapid-pvst I would run this instead of pvst.
If you use the extended system-id use it on all the switches including the root and secondary.
Jon
Edison Ortiz Fri, 02/29/2008 - 06:33
  • Hall of Fame,
    Founding Member
The system-id, along with the switch priority, and the allocated spanning-tree MAC address, enables to make the bridge ID unique for each Vlan in order to avoid a tie between 2 switches when electing the root for a Vlan.
For instance, if you configure a switch as a root for a Vlan and another switch as a root for the same Vlan, the switch with the lower MAC address will win the election process due to its system-id information.
HTH,
__
Edison.
