AP 1522 on pole
Feb 29th, 2008
Hi All,
I will installed two APs 1522 for mesh network on poles, is it necessary to buy the hand strap tool AIR-BAND-INST-TL and how many ? In the doc, there's a ref too for a Band Hand tool AIR-BAND-IT-TOOL, what's the difference ?
Thks for your response.
rob.huffman Sun, 03/02/2008 - 11:06
Hi Stephane,
This is the same tool indicated by the two part#'s. Not sure why the difference but it is the same part. This tool is required for tightening the Metal Bands. You should order at least one kit.
Tighten the metal bands using the band strap tool (Cisco AIR-BAND-IT-TOOL=), following the operating instructions in the box with the tool. Ensure the metal bands are as tight as possible.
Hope this helps!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
