Redistribute EIGRP into OSPF
aacj231210
---R1----R2-----R3----
I got 3 routers, R1/R2 ran OSPF,and R2/R3 ran EIGRP, now, there're lot of routes that just like 192.168.(1~10).0/24 come from R1,i wanna redistribute these routes into EIGRP process on R2.but now ,they require that the 192.168.2.0/24and 192.168.5.0 must be filtrated.but can not use " distribute-list" and "route-map"
what should i do?
thanks advance!!
Mohamed Sobair
Level 7
Level 7
you can acheive this by hyring the delay under the Eigrp process using (Offset-list) for the specific prefix.
example:
(offset-list 10 in 10000 ethernet 0)
access-list 10 permit 192.168.1.0 0.0.0.255
This would eleminate a route from being installed in Eigrp Topolgy table as a successor or a feasible successor.
In the above I gave it high delay (In Microsecond) value in order not to be considered.
Let us know if this acheived the requirement.
Mohamed
9 Replies 9
shivlu jain
Level 5
Level 5
Dear you can mark the routes with tages during redistribution and then drop the tags on the other routers.
regards
shivlu
thanks
should i adjust the metric?
Istvan_Rabai
Level 7
Level 7
Hi Yin,
The "can not use distribute-list and route-map" may have the meaning that you don't know how to use them, this is why here's some explanation from me:
It is fairly simple to do this with a distribute list like this:
access-list 1 deny 192.168.2.0 0.0.0.255
access-list 1 deny 192.168.5.0 0.0.0.255
access-list 1 permit any
Configuration under the routing process:
router eigrp 10
redistribute ospf 20 metric x x x x x
distribute-list 1 out ospf 20
Under the redistribute command the x x x x x means bandwidth, delay, reliability, load, and mtu. These configure the metric for routes redistributed into EIGRP.
You should configure these values, otherwise the metric will be 0 and no routes will be redistributed into EIGRP.
The access-list 1 and distribute-list 1 will filter out the desired routes from the redistributed routes.
Cheers:
Istvan
Istvan
thanks for your reply,
The meaning of "can not use distribute-list and route-map" is the topic requires that the "distribute-list" and the " route-map" must not appear in my configuration.
Hi Yin,
Thanks for the clarification.
Cheers:
Istvan
Mohamed Sobair
Level 7
Level 7
example:
Mohamed
using offset-list must adjust the metric to 2147483647,
before i adjust the metric
R3's eigrp topology table
P 192.168.9.1/32, 1 successors, FD is 284160
via 1.1.23.2 (284160/281600), FastEthernet1/0
P 192.168.8.1/32, 1 successors, FD is 284160
P 192.168.10.1/32, 1 successors, FD is 284160
P 192.168.1.1/32, 1 successors, FD is 284160
P 192.168.3.1/32, 1 successors, FD is 284160
P 192.168.2.1/32, 1 successors, FD is 284160
P 192.168.5.1/32, 1 successors, FD is 284160
P 192.168.4.1/32, 1 successors, FD is 284160
P 192.168.7.1/32, 1 successors, FD is 284160
P 192.168.6.1/32, 1 successors, FD is 284160
configuration:
R2:
access 10 permit 192.168.2.0 0.0.0.255
access 10 permit 192.168.5.0 0.0.0.255
router eigrp 1
redistribute ospf 1 metric 10000 100 255 1 1500
offset-list 10 out 2147483647 f1/0
R3
router eigrp 1
offset-list 10 in 2147483647 f1/0
Result
now the subnet 192.168.2.0 and 192.168.5.0 are
eliminated in the topology table.
thanks again for your reply
Istvan_Rabai
Level 7
Level 7
Hi Yin,
I found another simple solution for you:
On R2, where redistribution takes place, you can do the following config:
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 192.168.5.0 0.0.0.255
router ospf 1
distance 255 0.0.0.0 255.255.255.255 1
Raising the admin distance of the selected routes to 255 will filter the required routes from the routing table of R2.
In the routing table will be only 192.168.1.0 - 192.168.10.0 except 192.168.2.0 and 192.168.5.0.
EIGRP will of course redistribute only routes that are in the routing table and learned by OSPF.
I tried this on a living config and it works.
Cheers:
Istvan
i'll take a try for your project
by the way , thanks for your attention this topic,can i make friends with you? my MSN:
cj231514@hotmail.com, and you also can send E-mail to this mailbox.
thanks again
