02-29-2008 04:02 AM - edited 03-15-2019 09:09 AM
Customer wants to use TSP for click-to-dial from MS Outlook. However they synchronize their outlook contacts with their mobile phones, therefore they don't want to change the format of the numbers i.e. they want to keep +44 207 XXXXXXX or +1 418 XXX XXXX whereas CCM doesn't like that and wants no brackets, no plus (+) sign. Do you guys have any workaround for this? Maybe some configuration under Win XP Phone and modem Options?
Yigit
03-06-2008 09:12 AM
Try Bug - CSCsi63462
06-22-2008 09:37 PM
I would like to know if you find a solution to solve your issue cause I'm facing with the same need.
Best regards
