Caller ID restricted on Ä°P phone
Feb 29th, 2008
Iwant to use Caller ID restricted for example internal calls ip phone A DN1000 Ä°P phoneB DN1010 A call to B.Phone B not seen on screen(restricted) on ip phone
Overall Rating: 5 (1 ratings)
levinsky Fri, 02/29/2008 - 08:15
the only way you can block CLID in CCM is via a Translation Pattern or a Route Pattern. I have configured CLID blocking between internal phones by ensuring the CSS of the phones doesn't allow direct access to the extensions but only to a a Translation Pattern that blocks the CLID. The CSS of the Translation Pattern then has access to the partitions where the extensions sit.
Ken.
