3845 in rommon-no IOS
brooklynheight
I have a 3845 that we just found, it doesnt have a flash card installed so when it boots
up it goes to rommon
rommon 7 > reset
System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
Total memory size = 256 MB - DIMM0 = 256 MB, DIMM1 = 0 MB
c3845 processor with 262144 Kbytes of main memory
Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled
Readonly ROMMON initialized
Compact Flash: Not present
My question is-how can I change the regestry so it boots using internal memory?
I would like to see if their is an IOS image on that -is it confreg 0x2102...followed by reset?
and if there isn't an IOS on the internal memory, could I load one on there, without having to purchase
a new flash card?
paolo bevilacqua
ISR routers have no internal flash. You need a CF of good brand or a cisco original one.
In a pinch to boot, type tftpdnld -r, it will tell you the variables to set and you can boot from tftp server.
great ..thx!
by cf you mean cisco flash?
Compact Flash.
