DHCP Relay Over IPSEC VPN between a PIX and VPN Concentrator
Feb 29th, 2008
Dear all,
I am having problems getting DHCP relay working at a remote site
At the Main site i have a Windows 2003 DHCP Server behind a VPN Concentrator 3005
At the remote site i have a Cico PIX 501.
The VPN is workings correctly and can ping from both ends.
Unfortunately no matter what config i put into the Pix i can't get it to relay to the clients.
the config i have tried on the clients is..
dhcprelay server 192.168.1.1 outside
dhcprelay enable inside
dhcprelay setroute inside
and
dhcprelay server Outside_IP outside
and also have included tried both with the following lines in the access lists
access-list inside_nat0_outbound permit ip Outside_IP 255.255.255.255 192.168.1.0 255.255.255.0
access-list outside_cryptomap_10 permit ip Outside_IP 255.255.255.255 192.168.1.0 255.255.255.0
Can anyone help?
James
criitdept Mon, 03/17/2008 - 04:22
The VPN is working.
I have found a few articles and they have said that i need to setup a GRE VPN over ipsec to allow the dhcp broadcast, unfortunately this requires version 7 of the IOS on the PIX and as i only have a 501, this runs 6.3. so i'm now going to have to rethink my design.
Thanks for your help.
James
gerdpleyer Sat, 06/28/2008 - 06:44
Any update on this?
I almost want to do the same - but doesn't work via vpn.
mathias.mahnke Thu, 02/12/2009 - 08:19
We ran into the same issue. Didn't found any solution either. Any hints welcome.
