Cisco simulator
Feb 29th, 2008
hi all, i recall that Cisco in the past has released a adobe flash based cisco router simulator available for download for free. I cant seem to find it anymore. I am planning to study for my CCNA exam, does anyone know of any free simulator software? would really appreciate your help. thanks
Overall Rating: 2 (1 ratings)
I don't know of anything free released by Cisco. They do have a simulator for their Academy students, but not for the general public. It's called packet tracer.
I've heard of something called dynamips/dynagen. I've never used it, and I understand it's against Cisco licensing to use their IOS on a simulator such as dynamips.
I know that Boson and www.routersim.com sell simulators. I'm fairly certain that you get a simulator if you buy the platinum version of the Lammle CCNA study guide.
Hope this helps.
davehartburn Mon, 03/03/2008 - 07:13
As far as I can tell, dynamips simulates routers but not switches, which can be a problem for BCMSN.
The Boson router was all I needed for CCNA and is a very good product, however even the BSCI version was lacking for BSCI and useless for BCMSN. I very much doubt if it can do ISCW or ONT. On the whole, I felt upgrading was a waste of money ($150 if I recall correctly).
I've looked around for other simulators, but in the end scrounged old kit from work and bought the rest from e-bay.
GoBucks82 Mon, 03/03/2008 - 08:50
Although Dynamips doesn't directly emulate switches you can add a switch module to a router instance and there you go.
