DHCP Relay Over IPSEC VPN between a PIX and VPN Concentrator
Feb 29th, 2008
Dear all,
I am having problems getting DHCP relay working at a remote site
At the Main site i have a Windows 2003 DHCP Server behind a VPN Concentrator 3005
At the remote site i have a Cico PIX 501.
The VPN is workings correctly and can ping from both ends.
Unfortunately no matter what config i put into the Pix i can't get it to relay to the clients.
the config i have tried on the clients is..
dhcprelay server 192.168.1.1 outside
dhcprelay enable inside
dhcprelay setroute inside
and
dhcprelay server Outside_IP outside
and also have included tried both with the following lines in the access lists
access-list inside_nat0_outbound permit ip Outside_IP 255.255.255.255 192.168.1.0 255.255.255.0
access-list outside_cryptomap_10 permit ip Outside_IP 255.255.255.255 192.168.1.0 255.255.255.0
Can anyone help?
James
brettmilborrow Wed, 03/05/2008 - 14:28
Does the VPN tunnel come up? The one that uses the outside_cryptomap_10 access-list.
