mdi\mid-x
tpacjer
how can i turn off mdi\mdi-x on a catos switch
To enable or disable the automatic Media-Dependent Interface Crossover (MDIX) function, use the set port auto-mdix feature.
set port auto-mdix mod/port {enable | disable}
Reference: http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/command/reference/set_m_pi.html#wp1045648
I hope this helps.
Best regards.
Massimiliano.
that command is not listed this is the config i have. i am trying to stop people from looping the switch and looping hubs is there a command for this config or features i can enable/disable to prevent this from occuring
WS-C6509 Software, Version NmpSW: 6.4(9)
Copyright (c) 1995-2004 by Cisco Systems
NMP S/W compiled on Mar 10 2004, 17:31:52
System Bootstrap Version: 6.1(3)
Hardware Version: 2.0 Model: WS-C6509 Serial #: xxxxxxxxxxx
PS1 Module: WS-CAC-1300W Serial #: xxxxxxxxxxx
PS2 Module: WS-CAC-1300W Serial #: xxxxxxxxxxx
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE xxxxxxxxxxx Hw : 2.2
Fw : 6.1(3)
Fw1: 6.1(3)
Sw : 6.4(9)
Sw1: 6.4(9)
WS-F6K-PFC2 xxxxxxxxxxx Hw : 1.4
2 48 WS-X6348-RJ-45 xxxxxxxxxxx Hw : 1.5
Fw : 5.4(2)
Sw : 6.4(9)
3 48 WS-X6348-RJ-45 xxxxxxxxxxx Hw : 1.5
Fw : 5.4(2)
Sw : 6.4(9)
4 48 WS-X6348-RJ-45 xxxxxxxxxxx Hw : 1.5
Fw : 5.4(2)
Sw : 6.4(9)
5 48 WS-X6348-RJ-45 xxxxxxxxxxx Hw : 1.5
Fw : 5.4(2)
Sw : 6.4(9)
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 131072K 64597K 66475K 32768K 12483K 20285K 512K 372K 140K
