paolo bevilacqua Fri, 02/29/2008 - 08:58
  • Hall of Fame,
    Founding Member
With UC500/CME you have two choices for attendant console. First is CUE AA, that will support call by name, and can be customized with the CUE script editor.
Second is TCL/IVR, called B-ACD/AA, that will support a menu of choice for different groups, and more importantly, call queuing. In practice, you can do a nice call center with it.
Se depending on what you need to do, you use one or the other.
Rob Huffman Fri, 02/29/2008 - 10:55
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Andy,
Hope all is well :) Just to add a little to Paolo's always great info (5 points to you my friend for spending so much time developing these solutions for others to share :)
There is also Arc Express for CME
http://www.arcsolutions.com/NorthAmerica/Products/ArcExpress.html
Hope this helps!
Huff
paolo bevilacqua Fri, 02/29/2008 - 13:37
  • Hall of Fame,
    Founding Member
Whoops I realize now that I misunderstood the question, that is_not_ about Auto Attendant as I've misread.
So I rated Rob's post for bringing the thread back on track.
Incidentally I also wrote a sort of "status only" console for CME that can be downloaded at:
http://pbevila.fastmail.fm/public/CME%20Consolite/
