Broadcom virtual adapter - intergrated with two port on two different 6509
Feb 29th, 2008
I hv integrated two NIC through Virtual broadcam adapter(software) to two different cisco 6509 ports. Both cisco is interconnected and STP has been enable and working fine.
Server NIC MAC 1 - a.a.a.a
Server NIC MAC 2 - b.b.b.b
Virtual IP for broadcom - 10.10.10.10
Vlan : 60
Cisco 6509 -1 port : 7/2 ( nic a.a.a.a)
Cisco 6509 - 2 port : 7/4 ( nic b.b.b.b)
Issue I am facing is when I am viewing the CAM table enteries below is the result
Cisco 6509 - 1 Cam table
Mac a.a.a.a - port 7/2
Mac b.b.b.b - Port 1/1 (interconnected
port between
6509 switches )
Cisco 6509 - 2 Cam table
Mac a.a.a.a - port 1/1 (interconnected
port between
6509 switches)
Mac b.b.b.b - Port 7/4
But suprisingly seeing the ARP table I see two different MAC on the network for same IP
i.e
Cisco 6509-1 - 10.10.10.10 - a.a.a.a vlan60
Cisco 6509-2 - 10.10.10.10 - b.b.b.b vlan 60
This seems to be created some problem in the same vlan60.
How to resolve such issue with virtual server loadbalancing ?
Overall Rating: 5 (1 ratings)
robert.horrigan Sat, 03/01/2008 - 22:57
Those Broadcoms (or any other standard server nics for that matter i believe) will not load balance across seperate switches. The teaming software is designed for either redundancy (if a switch goes down it will default to the other) or mainly for double the speed - and you have to plug them into the same switch and enable etherchannel. Right now you are seeing what the switches should be expecting from the server software.
sandeepatel Mon, 03/03/2008 - 05:20
Thanks Robert,
curious on that ,
How I can configure the perferct method to configure server load balancing with teaming NIC on the system side and also Network load balancing on the Network side.
so i don't only hv the SLB but also NLB with high high redundancy.
