SXH + MPLS + EBGP
Hi!
My company has Cisco 6506 with SUP720-3BXL.
I'm trying to kill two birds with one stone
2 BGP Full View + MPLS VPN in one box.
I have a problem with more than 250k labels in LFIB.
Seems it creates a new label for each prefix recived from BGP.
How it can be turned off ?
IOS 12.2 SXH adv ent services.
L3 Forwarding Resources
FIB TCAM usage: Total Used %Used
72 bits (IPv4, MPLS, EoM) 524288 459356 88%
144 bits (IP mcast, IPv6) 262144 7 1%
detail: Protocol Used %Used
IPv4 243728 46%
MPLS 215627 41%
#sh mpls ip binding summary
Total number of prefixes: 211
Generic label bindings
assigned learned
prefixes in labels out labels
211 210 416
Total tib route info allocated: 194
bbn-ms-gw#debug bgp ipv4 unicast mpls
BGP MPLS labels debugging is on
2w0d: BGP: adding MPLS label to 202.52.15.0/24 sending labels not enabled
2w0d: BGP: adding MPLS label to 202.52.12.0/24 sending labels not enabled
Why it added MPLS label to prefix?
Noone told it to do that.
olorunloba Fri, 02/29/2008 - 16:28
  • Silver, 250 points or more
For routes earned via BGP, MPLS does not assign labels, but use the label for the BGP next hop.
The output of your show ip binding summary shows that 210 labels hass been assigned.
Harold Ritter Fri, 03/07/2008 - 10:01
  • Cisco Employee,
Pavel,
Are the full Internet feeds in VRFs.
If so, IOS allocates one label per VRF prefix. you can use the following command to force IOS to allocate only 1 label per VRF:
mpls label mode { vrf | all-vrfs }protocol bgp_vpnv4 per-vrf
BTW, this is a hidden command.
Hope this helps,
