linux vpnclient
Feb 29th, 2008
I'm trying to configure a linux kernel to use certificates for authentication. everything compiled fine and installed with no problems. my issue is that when I try to import the vpn's public cert via
cisco_cert_mgr -R -op import
I get the message that says that the import was successful, but when I use
isco_cert_mgr -R -op list
to see if it is there, the certificate is not listed.
Any help will be appreciated.
