Unity fails to start after a reboot
Feb 29th, 2008
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
I've juts installed Unity 5.0 in VMO environment, where a pair of Unity servers are DC/GC, whenever I reboot a server Unity fails to start, however manual start works just fine and all appears to be fine. I am repeatedly seeing the following error in the event viewer:
Source: CiscoUnity_AvRdbSvr
Event ID: 21000
Failed connecting to underlying database using: provider=SQLOLEDB;driver={SQL Server};Data Source=HQDCUNTYPRI1;Initial Catalog=UnityDb;uid=Administrator;pwd=<?}: 80004005
SQL Server starts just fine, I can connect to UnityDB, I am thinking this may be due to a some domain policy.
Has anyone encountered this?
Chris
twissam Sat, 03/01/2008 - 11:06
i never faced this with Unity, but with CCM.
i donno why this is happening, but as a workaround you can go the unity services and select the recorvery action (restart the service after 3 min)
Good luck
ranpierce Tue, 03/04/2008 - 10:37
  • Silver, 250 points or more
Question: VMO voice mail only? cause VMO stands for Viewmail for Outlook.
So how is it set up? Need more information.
rlp
Ginger Dillon Tue, 03/04/2008 - 11:08
  • Blue, 1500 points or more
Hi -
Error code 80004005 is typically a permissions related issue, although I don't know why it is occuring in your situation. Have you checked BugTrac on Cisco or called TAC on this yet>
Ginger
Chris Deren Tue, 03/04/2008 - 12:24
  • Hall of Fame,
I've got it resolved by changing the Unity gateway service set to recover on second and third time.
P.S. VMO stands for VoiceMail Only as oppose to UM - Unified Messaging.
Chris
ranpierce Tue, 03/04/2008 - 12:52
Glad you got it fixed. (really)
VMO is a tool in UM so it cannot be an acronym (as apposed) to UM.
I just am clearing this up not wanting to get in a contest about it.
rlp
