LMS 2.6: Long-running ChangeAuditDefaultPurge job
Answered Question
Feb 29th, 2008
  • Gold, 750 points or more
I've been trying to find out why my LMS 2.6 backups are getting bigger by several hundred MBs a day again. I've known /var/adm/CSCOpx/files/rme/dcma/difffiles/ is the one doing the growing, but I finally find this is because the daily ChangeAuditDefaultPurge job kicked off at Feb. 25 at 2am has not finished running even to this moment. Is there any remedy to this situation? Is it safe to stop the job? /var/adm/CSCOpx/files/rme/jobs/cas/1393.log shows the Change Audit purge has not been running daily, as scheduled:
[ Tue Jan 22 02:00:05 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.util.db.Databa
seConnectionPool,getConnection,59,Inside ICSDatabaseConnection, MAX_COUNT =20
[ Tue Jan 22 02:00:08 EST 2008 ],INFO ,[main],Successfully deleted 279 ChangeAu
dit records
[ Sat Jan 26 02:00:05 EST 2008 ],INFO ,[main],Successfully deleted 21 Audit tra
il records
[ Sat Jan 26 02:00:07 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.util.db.Databa
[ Sat Jan 26 02:00:20 EST 2008 ],INFO ,[main],Successfully deleted 1044 ChangeA
udit records
[ Sat Feb 23 02:00:04 EST 2008 ],INFO ,[main],Successfully deleted 190 Audit tr
ail records
[ Sat Feb 23 02:00:06 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.util.db.Databa
[ Sat Feb 23 02:07:22 EST 2008 ],INFO ,[main],Successfully deleted 7420 ChangeA
udit records
[ Mon Feb 25 02:00:05 EST 2008 ],INFO ,[main],Successfully deleted 15 Audit tra
il records
[ Mon Feb 25 02:00:06 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.util.db.Databa
[ Mon Feb 25 02:00:13 EST 2008 ],INFO ,[main],Successfully deleted 908 ChangeAu
dit records
I tried to stop the job (#1393) via the web GUI but got the response it "could not be stopped".
Correct Answer by Joe Clarke about 9 years 3 months ago
The difffiles are not purged automatically. You can manually delete them, however, as they are not referenced by anything. They will be recreated as needed.
This sounds like CSCsm03001. I have a patch available you can get by calling the TAC. To stop this job, you will need to restart dmgtd.
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Fri, 02/29/2008 - 13:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
yjdabear Tue, 03/18/2008 - 07:59
The patch works, but my dcma/difffiles directory is still adding hundreds of MBs a day. Take today's Change Audit purge for example (30-day retention for both change audit and audit trail records):
Job ID: 1393 Status: Succeeded
Job Summary
Change Audit Purge: Succeeded
Purge Change Audit Records older than : Feb 17 2008
Job Type: Change Audit Default Purge
Audit Trail Purge: Succeeded
Number of Audit Trail Records purged: 88
Purge Audit Trail Records older than : Feb 17 2008
Purge ended at : 2008-03-18 01:00:51
Purge started at : 2008-03-18 01:00:04
Number of Change Audit Records purged: 5127
Yet, I'm still finding diff files from as old as Dec 7, 2007.
/var/adm/CSCOpx/files/rme/dcma/difffiles/379/PRIMARY/RUNNING)->ls -al
total 2
drwxrwx--- 29 casuser casusers 1024 Mar 18 02:37 .
drwxrwx--- 3 casuser casusers 96 Dec 7 10:07 ..
drwxrwx--- 2 casuser casusers 96 Jan 18 08:23 2
drwxrwx--- 2 casuser casusers 96 Dec 7 10:07 25
drwxrwx--- 2 casuser casusers 96 Jan 25 02:01 33
drwxrwx--- 2 casuser casusers 96 Jan 25 02:01 34
drwxrwx--- 2 casuser casusers 96 Jan 31 01:58 35
drwxrwx--- 2 casuser casusers 96 Feb 2 01:56 36
drwxrwx--- 2 casuser casusers 96 Feb 2 01:56 37
drwxrwx--- 2 casuser casusers 96 Feb 3 01:46 38
drwxrwx--- 2 casuser casusers 96 Feb 7 02:34 39
drwxrwx--- 2 casuser casusers 96 Feb 7 02:34 40
drwxrwx--- 2 casuser casusers 96 Feb 7 02:34 41
drwxrwx--- 2 casuser casusers 96 Feb 8 02:00 42
drwxrwx--- 2 casuser casusers 96 Feb 14 01:50 43
drwxrwx--- 2 casuser casusers 96 Feb 21 01:51 44
drwxrwx--- 2 casuser casusers 96 Mar 6 01:56 45
drwxrwx--- 2 casuser casusers 96 Mar 7 01:54 46
drwxrwx--- 2 casuser casusers 96 Mar 7 01:54 47
drwxrwx--- 2 casuser casusers 96 Mar 7 01:54 48
drwxrwx--- 2 casuser casusers 96 Mar 8 02:00 49
drwxrwx--- 2 casuser casusers 96 Mar 8 02:00 50
drwxrwx--- 2 casuser casusers 96 Mar 13 01:55 51
drwxrwx--- 2 casuser casusers 96 Mar 13 01:55 52
drwxrwx--- 2 casuser casusers 96 Mar 14 01:50 53
drwxrwx--- 2 casuser casusers 96 Mar 14 01:51 54
drwxrwx--- 2 casuser casusers 96 Mar 14 01:51 55
drwxrwx--- 2 casuser casusers 96 Mar 15 02:03 56
drwxrwx--- 2 casuser casusers 96 Mar 18 02:37 57
Correct Answer
Joe Clarke Tue, 03/18/2008 - 09:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
