Make an L3 VLAN to a L2 vlan
Feb 29th, 2008
switch is CatIOS 12.2x
I have a vlan on a 6509 that someone made a Vlan layer3 that should be layer 2. What is the most simple method to fix this.
1) no interface vlan xx
That deletes the L3 interface
2) go into the L3 inteface and give it a "no ip address".
I don't want the interface to "drop" about 100 servers on this vlan.
my predecessor method to create a Layer 2 vlan was to create L3 vlan interfaces but give them no ip address.
Me I just create the L2 vlan in confg-lan mode and don't do a config t/interface vlan xxx
Any advantages over either method?
I naturally think mine is better. Less work, less confusion as to what is L2 and L3 on the switch at a quick glance
Roman Rodichev Fri, 02/29/2008 - 13:31
  • Gold, 750 points or more
yours is better
just remove interface with "no interface vlan xx" make sure no server points its default gateway to the SVI IP address
Istvan_Rabai Fri, 02/29/2008 - 20:21
Hi Doug,
Of course, your way is OK.
For a vlan to operate as a layer 2 broadcast domain, there is no need to have a vlan interface.
Vlan interfaces are needed when you want to route your traffic out of that vlan.
Cheers:
Istvan
