MROUTE-3-NO_PIM_NBR- Says there is no neighbor
Feb 29th, 2008
I have a cisco 7507 connecting to an adtran router. I have multicast set up between the two devices- and multicast traffic actually passes. However, in the logs I am receiving this:
Feb 29 15:21:14 CST: %MROUTE-3-NO_PIM_NBR: VRF Morgan: There is no PIM neighbor on this IDB: Serial5/0/0:12 -Process= "PIM Process", ipl= 0, pid= 163
Yet, if i do a sh ip pim vrf Morgan int s5/0/0:12 I get the following:
X.X.X.X (deleted address) Serial5/0/0:12 v2/S 0 30 1 0.0.0.0
and traffic IS passing. This is one of 25 sites configured this way, all with the exact same config. Yet, this is the ONLY one that is having this problem. Ideas?
htarra Thu, 03/06/2008 - 14:41
  • Bronze, 100 points or more
Here is the explanation of the error messege
MROUTE-3-NO_PIM_NBR : There is no PIM neighbor on this IDB: [chars]
The message indicates that there is no PIM neighbor on the interface. The behavior that
the message comes up after PIM neighbor down is correct.
explanation : There is no PIM neighbor on the specified IDB. The most probable cause of
this error is that PIM is not configured correctly on this interface or on interfaces of
the next-hop routers.
Recommended Action : Check PIM configurations on local and neighbor routers.
